rtcc Posted November 9, 2007 Report Posted November 9, 2007 My headlights are getting power, but just enough to make the filiment glow, but not put out any light. What else could be causing this besides the voltage regulator? thanks Quote
blowit Posted November 10, 2007 Report Posted November 10, 2007 My headlights are getting power, but just enough to make the filiment glow, but not put out any light. What else could be causing this besides the voltage regulator? thanks un-couple the lighting coil from harness. Black and yellow wires, remove the blue wire from the reg, remove all light bulbs, use an ohm meter to test from the harness side yellow wire to ground. If you have anything at all other than open line "OL", then you have a short somewhere. Before I went that far, I would test the output with the regulator plugged in. Use AC on your meter. anything under 11.5 is a problem and should be over 13. Brandon Quote
