Up for grabs is my drag bike.. I Just finished the build about a month ago and it's been out to the strip twice.. Less than 15 1/8th mile passes on it.. The only reason i'm selling is to fund a car project. Only thing left stock on the bike is the a-arms and ingnition system. No short cut's taken with this quad. Started building it in september of '06 and finished it September of '07. It was built from the ground up so everything has been went through. The bike has all new bearings, seals and bushings. Motor has 185lbs of compression @ 2000 feet elevation. There is absouloty nothing at all wrong with it, just want to build a car. Mod list is as followed..
-Engine-
68mm Cheetah Cub cylinders
Hot Rods Long rod 4mm Stroker Crank
1-5 RDZ override Trans. with neutral down
Port Matched Cases
CPI out of frame Drag Pipes for Small Bore
FLOW TECK Lightened Flywheel
Cut Stator for 4 deg. Timing advance
39mm PWK air stryker Alky carbs
Dave Moore Powerjets for methanol
K&N Clamp On filters with outerwears
Mikuni Fuel pump
Billet Clutch Basket
Barnett R6 Clutch System
Majic Performance Clutch Lockup
Pro Design Cool Head
Majic Performance 18cc domes
Wiseco Pro lite 68mm Blaster pistons
Trinity Stage lV Intakes with Crossover tube elimator
TDR epoxy reed with ported cages
TDR Reed Spacers
Pingel Dual Feed Fuel Valve
All bolts replaced with Stainless allen head and acorn nuts
-Body-
Lightened, 3 stage pc'd Frame with all excess tabs removed
CFM +6'' Swingarm
8500 ft lb non o-ring chain
Polished Axle
Custom Cut seat
front lowering shock
05' Special edition plastics
Custom Graphics(Special made by BRMoffroad, only set in the country)
Custom Grill by H3welds
Billet Amber Light Headlights
UPP Long Chain slide system
All cables by Pro motion
Adjustable Ride height Rear Strut
Adjustable Wheelie bar
Chrome Drag Bars
MSR levers
Chrome Shifter and brake Lever
Stainless brake line
Double wide foot pegs
ITP .190 wheels
Hoosier 60-15-10 Rear tires
Billet Hi-Flow Gas Cap
Majic Performance EZ change clutch cover
TON'S OF BILLET AND CHROME!! I'm not gonna list it all just look at the pics..
That's all i can remember atm, i'm sure there is much more i'm overlooking.. Ask anybody who's seen this bike it's super clean and very fast! Asking $7500 OBO or will consider trade for a V8 mustang/muscle car of equal value.. Will also take a lesser valued car and some boot.. Bike will be at I40 dragway in crossville this saturday if potential buyers would like to have a look at it or watch it run.. This really is a TURN KEY AND FLY!
Edited by Lethaface
BUMP for a super ass clean bike.. runs like a raped ape!!! like it says ground up build.. hate to see it go germ like mine, but good luck on the sale and thats a dang steal for this bike.. you better let me ride this weekend if im able!! lol... :cool:
ANY CHANCE OF PARTING
Not at the moment. I wanna sell out right but if it dosn't sell o i get no offers i may consider it.
Thanks stacy, as long as your able your more than welcome.
