ok,guys i am from Panama so sorry for my english.
my banshee was runring great until one of the pistons stop running then after a few seconds of the banshee runinng with only one piston it turned of
i tried starting it again but nothing. I even tried turning it on by been toed by another fourwheel but nothing. I waited a few hours and tried to kick start it again and to my suprise it started at the first kick.
So everything good until i arrived home from my trip the banshee wont start again and i tried to kick start it and tried a moving start but nothing what can it be???
the plugs being black means your running rich. you have too much fuel going to the motor, you need to take off your carbs and put smaller jets in there... make a list of any mods that are on the bike. and what elevtio you ride at and we cn get your jetting close.
when you flood the motor your plug gets wet and wiwll not spark making your motor not run... to fix it you either have to let the motor sit or open the throttle wide opnen with the gas and ignition off and kick it over and try to blow any fule out... the second method does not always work.
yes if you mix it to rich you can be getting too much oil. you only want to mix it 32:1 - 40:1 depending on what oil you use. but either way your jetting is off letting too much fuel in. you need smaller jets your plugs should looks lite brown like a paper sack. not black
Edited by Bansh-eman
