Hi all, please can you help me on air filter size, i am running a 16mm 600 T Rex with CPI Banshee 6's and 38mm carbs, with length air filters do you think i should be using so i dont restrict the power?
i run 8s on a 543 they have 12' pods justs get the 12s no worrys at that point ,thats enough air for a big block chevy
hows the weather over there in england mike
Its a bit cold at the moment for us, about 5 Celcius. But then we always have rubbish weather over here!! What sort of rear wheel horsepower does your 543 have, i am trying to get mine dialed in at the moment and need some benchmarks.
Hi guys, i know my T-REX wont make quite as much power as the modern cylinders but where do you guys think i should be from my set-up (38mm carbs, CPI banshee 6's, stock ignition, 12.1:1 compression ratio, fully race ported, power peak at 9500rpm) any horsepower figures or dyno graphs from similar T-Rex motors would be very much helpful. Any advice or numbers to aim for please!
