wood Posted October 25, 2007 Report Posted October 25, 2007 i thought the slides could only go in one way. Quote
Snopczynski Posted October 25, 2007 Report Posted October 25, 2007 left to right and vice versa. You probably should make sure the choke balance tube is on while your at it. Quote
jaredvh Posted October 26, 2007 Author Report Posted October 26, 2007 Well..when my banshee was warming up today I decided to try something. I covered the left exhaust tip and there was pressure there but nowhere near as much as it should be because it stayed running. When I went to caver the right tip the banshee just about stalled out but I uncovered it before it stalled. I'm kind of worried now because I dont assume that it's a good thing Quote
The Rebel Posted October 27, 2007 Report Posted October 27, 2007 switch reeds and see what happens. it could be bad pedals. Could be bad "pedals", I had to replace the pedals on my baby's tricycle once because one side pulled harder than the other causing a terrible drift when under power. Quote
The Rebel Posted October 27, 2007 Report Posted October 27, 2007 i thought the slides could only go in one way. They can be switched from one carb to the other and still fit. Just that the cutaway will not be in the proper position. That doesn't sound like what is wrong here though. Sounds like you might need to do a leakdown test. Quote
