yamaperv Posted October 12, 2007 Report Posted October 12, 2007 I was just wondering if there should be any play in the rear sprocket hub I don't really think so, but I checked on my craptor too and it also has play, or are they both screwed? Quote
Bansh-eman Posted October 12, 2007 Report Posted October 12, 2007 it shouldnt move i any direction, if if moves side to side your axle is loose. if it move forward and backwards on the axle its becasue your splines are being worn down in either the hub or the axle. more then likely the hub becasue its softer metal Quote
yamaperv Posted October 12, 2007 Author Report Posted October 12, 2007 it shouldnt move i any direction, if if moves side to side your axle is loose. if it move forward and backwards on the axle its becasue your splines are being worn down in either the hub or the axle. more then likely the hub becasue its softer metal Oh okay that is what I thought, I don't think that should be to costly to repair. The only thing that threw me off is the craptor being the same way. Quote
