i have a banshee bored 2 over with pro design coolhead with 19cc domes and toomey t5 pipes, i just got a kehien 2-1 setup and im hoping someone can point me into the right direction so i dont have to buy a 100 jets trying to figure it out. thanks
Need alittle more info,What altitude do you have stock or aftermarket reed system What size carb is it R U runing it with the air box or a clamp on filter?
i have boyseen reeds and a clamp on filter. and the carb is a 35m
and i live in so cal so most my ridings done in glamis.
You'll be around a 190-195 main and more then likely a 50 pilot.The needle in the 35 should work you'll just need to play with the clip positions to dial it in.
