jedsled Posted October 9, 2007 Report Posted October 9, 2007 i understand that .100 (66.5mm) is the last bore that you can go out on stock banshee cylinders, but are there any concerns i should be aware of for going to that large of a bore such as overheating or a greater chance of piston seizing? the cylinders are ported and i would hate to waste the porting. i know that i can re-sleeve and re-port, but that costs almost as much as porting alone! thanks. Quote
Bansh-eman Posted October 9, 2007 Report Posted October 9, 2007 i think the main concern is busting through to the water jackets. cooling and seizeing shouldnt be any more of an issue as long as your tolerances are set correctly. Quote
jedsled Posted October 10, 2007 Author Report Posted October 10, 2007 i think the main concern is busting through to the water jackets. cooling and seizeing shouldnt be any more of an issue as long as your tolerances are set correctly. ok, thanks for responding. Quote
