I just bought a 2003 banshee a couple of months ago. I put a couple of new modifications on it. A 4 mm vito crank, 19cc domes, with cool head, bored 80ths. with a really aggressive trail port and polish by Kevin Jerr in Ca. It has a 200watt stator with a adjustable timing plate set at 4 degrees, also a high rev cdi box. The bike has FMF SST pipes installed on it with a K&N air filter in stock air box. The bike has stock carbs. I also put the delta 3 reeds on it with the reed spacers. Can someone please let me know how to set the carbs up or at least put me in the ball park. This is the first time I
A decent starting point should be:
300 mains
27.5 pilots
needles on 4th clip postion
air screws 1 turn out.
Remember... this is a starting point, you'll have to make minor adjustments!
