List the mods, first things first & you'll get accurate answers.
I'd say make sure you're mixing your gas with a good quality oil, I use Maxima.
You don't want to fry the cylinders. Second, keep that air filter clean. Also check fluid levels..
Check the bike for leaks, make sure nothing is wet.
Post pics of that 2000, let's see wutcha got???
i can remember wisco, toomy t5's,bored 2 over, something blue axle?, dg bumber, i cant remember the rest
Those are a good start for some mods. You have a DuraBlue axle, nice. T5's are nice pipes too. You have Wiseco pistons and it sounds like your motor, at least your top end, has been rebuilt. It would be important to know if any porting has been done to the jugs. And it would be good to know if the head is after market or work done to it. You need to know what size domes' are in there. This will clue us into what compression you are running, very important. I wonder about all of this since it may have been rebuilt who knows what he could have had done. Can you contact the seller and ask him about everything again?
yea i know there is cool heads also, as weel if you can tell from the pic he put a larger gas tank on it nice for northeastern PA since long rides are easy to get into
