Yes, they all need to be torqued in order 1-10 , start at 5 then 10,15,20 - 20 is the maximum(ft-lb). The base is the same procedure(same ft-lb), just cross them up like you would a wheel on a car. Also, before I put the head back on, if its stock, make sure the heads not warped, put it on a flat pice of glass, or something you KNOW is flat. The limit is .03mm i believe. Goodluck
Eric
