a friend of mine has a 7mil trex motor ported by rossier engineering.
it has 39mm pwms and trinity stage 4 pipes, vortex ignition
what do you all think it would rev to?
I'd ask Rossier...they could tell you.
Porting, pipes, compression, intakes, timing....all play a role on how high it'll rev...
But remember, doesn't do any good to rev to 11K if the power falls off at 9...
Dyno baby...the only way to go.
im just trying to work out what top speed he might be able to pull
i thought that with the longer stroke, and bigger/heavier pistons, that it might not be physcially able to rev as high as say a drag ported 350cc banshee, but he would obviously have alot more power/torque to pull much taller gearing...
would you agree?
thats about right , i had a 7 mil t rex 72 bore and it fell off quick pretty much a dog compared to a cub imo my cub i had pulled hard all the way and never quit with shearer pipes .
would you agree?
It's probably a trade off....to be honest. Not revving as high will probably cancel out bigger gearing...
Unless that TRex has EXTENSIVE porting done by someone who knows what they're doing....it's not going to make the power a cleaned up cub will....
I know rossier makes great 4 stroke products. I'm unaware of their 2 stroke capability....
get one of those cheap tachs that wrap around your spark plug wire and see how high it revs :shrug:
