The Faster Cracker Posted September 5, 2007 Report Posted September 5, 2007 ok i have an opportunity to either get a prodesign or a modquad coolhead for dirt cheap! i want to eventually put a 4 mil stroker in her but i couldnt find coolhead domes for a 4 mil stroker that fit the pro design head. modquad offers domes for the 4 mil stroker. does this make a diffrence? i also want to run pump gas if possible but i will run race or 50/50 if neccessary. also looking at getting a play port done as well but i will be puttin time on the banshee before i get the port job done. i am basically sea level elevation in central texas. so what size domes so i need or should i run? shold i get the prodesign or modquad head? what else do i need to do just to install the cool head? thanx for the help fellas Quote
wesw Posted September 5, 2007 Report Posted September 5, 2007 get with david noss dlnoss on here. he can make you any domes you want. also you should get it ported for the 4mm before getting all this stuff going. imo Quote
Bansh-eman Posted September 5, 2007 Report Posted September 5, 2007 not sure about the modquad head but the PD you will have to replace your studs. all domes are interchangeable with PD ad NOSS .... um theres one more but its slipping through right now... if your wanting to stay with pump you can either stick with stock size domes which are about 22cc. or maybe get away with some 21s but youll need to do a compression tst once you get them in there and see for sure. Quote
The Faster Cracker Posted September 5, 2007 Author Report Posted September 5, 2007 get with david noss dlnoss on here. he can make you any domes you want. also you should get it ported for the 4mm before getting all this stuff going. imo i probably wont get the 4 mil for another year or so! do i need to still get it ported now or can i wait and get it done when i tear it down to put the crank in? im trying to minimize down time as much as possible since its prime riding season now. also, do i need to get the timing plate now fo the cool head or can i hold off for the stroker? Quote
