it will feel like you have half a gear less, like third will be like halfway between where 2nd and 3rd were before.
its nice if you ride lots of tight trails because first gear is a little lower so you dont have to bomb through the tight stuff or use the clutch as much.
you will have to shift more often though
edit- im not sure about the chain length, if you have lots of adjustment left it should be ok
Edited by shee rips
