bansheeyfz Posted August 26, 2007 Report Posted August 26, 2007 will i have to change my chain length? will i have more low end if i switch to a 13 tooth Quote
shee rips Posted August 26, 2007 Report Posted August 26, 2007 (edited) it will feel like you have half a gear less, like third will be like halfway between where 2nd and 3rd were before. its nice if you ride lots of tight trails because first gear is a little lower so you dont have to bomb through the tight stuff or use the clutch as much. you will have to shift more often though edit- im not sure about the chain length, if you have lots of adjustment left it should be ok Edited August 26, 2007 by shee rips Quote
