if im at sea level then i should have a 130psi right and im gonna run it at 32:1 and im going with a 15frt and 41rear
You just said you had 150 psi compression. The higher the elevation, the lower the compression number. Where did gearing come from all of the sudden? Gearing is usually on a case to case scenario, and we cant really even begin to give you a starting point for it without knowing your riding scenario, tire sizes, etc......
your right on that, excuse me on that.but, i did have a 150psi on the left, and a 145psi on the right. now ,remember i changed the left one .so it might just need to break in a bit you think.
I would not be too worried about a 5 psi difference.
i know thats only because its broken in more i bet datz y itz wet on the left side and with that 150 psi can i put the timing back to the stock one i know my mechanic played with it but i dont know how much
Well, when I was breaking my bike in, the plugs looked even on both sides, and neither one was wet.
