you didnt hotwire it right somehow? I lost or someone stole my key.make sure your not letting any wires ground out and double check your connections.
It should run fine, i dont have a key at all, make sure the wires are connected properly (solder is where its at/ heat rap after). Sounds like a problem with your wiring...
