samc Posted August 13, 2007 Report Posted August 13, 2007 okay since im on a budget to get my banshee going can i reuse the same metal gaskets? i was thinking about putting gasket sealent on them to seal up real good. also my gas tank so so hard to get off idk why but i dont think its the right one. are all the gastanks the same on banshee all years or they just plain hard to get off? i ended up putting a hole in mine and i was thinking about putting plastic expoxy on it but i think the gas might eat right threw the epxoy. Quote
peak-j Posted August 13, 2007 Report Posted August 13, 2007 Don't reuse the old gaskets, just go buy new ones. On the gas tank, find someone that can weld plastic, or buy a used one somewhere. Plastic welding works good, I have welded a few tanks out of cars, and it would be cheaper than a new one. That is if anyone around you can weld it. The epoxy would probably end up falling off. Quote
samc Posted August 13, 2007 Author Report Posted August 13, 2007 thanks, all tanks fit all years? this one just dont want to come off and when i got it off it wont go back on. Quote
