2005 Shee, normal mods of Pro Flow with K&N, FMFs, the normal stuff. I was riding and all of sudden I didn't have any power bottom end, it was fine at high RMPS but it didn't want to idle either. I felt the exhaust and my left side is running air out just as cool as outside temp, when I reved it up it got a little warmer but has 1/4 of the pressure as the right side. I switched everything I could to try to find the problem, I swithced plugs, wires, I even had an extra carb I switched on it and still does the exact same thing on the exact same side. I checked and there is no leaks, I can't hear a difference, I am lost......what could it be? Any suggestions would be greatly appreciated.
Well that cylinder is not running and you need to figure out if it is fuel or ignition related. I would think you either lost compression on that cylinder or something clogged up the carb. If you put a new plug in and swapped wires and that did not fix it, it is not ignition related.
Brandon
I tripple checked the plugs and wires, I am almost 100% sure its not that, I also put the choke tube on when I switched carbs. I will check my reeds when I go out but could it be something worse...could I have wasted the piston already. I am running the normal mods with 280 mains and plugs have always looked good....I appreciate the help though.
