just bought a 7 mil t-rex motor it is a 71.25 bore the problem is that it don't seem to be making any big power i have a stock cyl 4 mil that feals twice as stong. anybody have any suggestios or are these things even worth having let me know
i have power pro drag pipes
with 36 pj's on alcohol
v-force reeds
160 psi compression
timing at +4
it really seems weak on the bottom not snappy enough for me on top it feels ok but not anything special
thanks
v-force reeds
160 psi compression
timing at +4
thanks
Give it some more timing.....I would like to see it around +8-10
I'm going to try that tonight i talked to some people today and they say i might have a set of the old cylinders which with the best port job will only make around 80hp if that is the case these cyl will be for sale i cannot compete with that
thanks for the suggestion if you come up with anything else let me know
