motocrossrider68 Posted July 3, 2007 Report Posted July 3, 2007 this banshee is custom Painted with a really expensive paint job that has lots of detail to it pictures dont do it justice. the motor work done to it is: Ported & polished ported cases welded crank ported read cages boyesen reeds dual 35mm keihn pwk carbs trinity t5 exhaust k&n filters pro lite pistons the following parts are either chromed or polished on it: a arms swingarm tie rods clutch cover cylinders and head brake resevoir everything on the handlebars footpegs brake pedal shifter and many more.... includes a full set of front and rear sand tires 10 paddle haulers in the rear The bike was fully rebuilt last winter. from the frame up removed every nut and bolt and inspected everything. anything needing replaced was at the time. the motor was also rebuilt at the same time all the seals and bearings were replaced and anything that looked worn. you can reach me at 253-495-9354. this bike has been very reliable i havent had one problem with it. usually starts on the first kick. 4500 i need to sell this asap. Quote
