markyb31 Posted June 30, 2007 Report Posted June 30, 2007 What size chain roller is used for the upper roller. I just bought a 94 banshee and it had this after market chain roller on it that is attached at the swing arm shaft and the old upper chain roller location, it is made by AMP. It has an upper and a lower sprocket instead of roller. They look just like a front drive sprocket with the teeth almost worn down to nothing. The problem is the upper one is missing. I decided to go back to using the stock location and plastic rollers. I got two 43mm rollers (dealer told me that is what I needed) the top on is so close to the frame the chain does not fit in between the roller and the frame. I think I am mounting it in the right place. There is only one other hole back there and I think that is for mounting the heel gaurd. What is going on? Quote
markyb31 Posted June 30, 2007 Author Report Posted June 30, 2007 Never mind. I am an idiot! I was trying to go over the top roller for some f'in reason . Quote
