Cleaned carbs, I did`t touch any settings, NOTHING, now it won`t idle, but revs great, what is wrong ? Thanks Milo_32000
choke tube connected?
Check pilots jets! A very small piece of dirt or sand really messes them up. On the stock carbs there is a small hole drilled in the side of the slides and on the carbs toward the top of the slide body you can see a small sight glass. It is on the right side and back slightly. When you open the throttle you can see the slides move up, the holes on the slides should match on both carbs in the sight glass. If not you need to adjust them to match. Hope that helps. :cool:
