I don't think it would change it that much, ofcourse i don't know how the T6s perform i have t5s. I would think it would help it more less. Where are you at 2500 above or below sea level?
I'm at Elevation: 1066 ft / 325 m
elevation wouldnt make any real difference in if you had to bump it up, unless the obvious you changed it. Prob wont need to, but then again pods do suck a good deal air. Take it for a small rip when you change it and see if its pingie or anything and it sounds n runs alright and doesnt heat up faster than normal, n, do a plug chop. You might actually need to go up a size or 2.
Toomey's have a natural " ping " to them in the pipe area dont they? or is that with all aftermarket pipes? ive always had a ping since i put the pipes on but every banshee with t5's or t6's that ive heard have the ping at idle from the front area of the pipes ... or am i getting my " pings " mixed up :)
I had both air filter setups, 1 into 2 Toomey foam w/ outerwear, and the pod filters.
Same jetting for both...I used one as a backup on a long weekend of trail riding, instead of having to clean one or the other....
