HKIC Posted June 8, 2007 Report Posted June 8, 2007 I was wondering what i would need in order to get a 4mm cheetah cub without the engine kit? and which pipes should i use? thanks Quote
dajogejr Posted June 8, 2007 Report Posted June 8, 2007 I was wondering what i would need in order to get a 4mm cheetah cub without the engine kit? and which pipes should i use? thanks Please use the search button, this has been covered a gazillion times. Make sure you are ready for everything you need to run a cub, not just a cylinder...by that I mean override trans, lockup clutch, longer swingarm, new pipes, new paddles, new carbs (if you don't have larger ones already)... That's just the tip of the iceberg.... Quote
HKIC Posted June 8, 2007 Author Report Posted June 8, 2007 thanks. yea, im at school right now.... for some reason it wouldnt let me use the search button.... Quote
