last week end i wos riding and saw that my chain wos loose so i set it on a block and notest that the swing arm wos moving wear it meets the frame. the bolt that hoolds it wos tiet what is rong with it
i think it is the bushings but i am not shure
it wos moving about 3-4'' at the end of the swingarm
:confused:
:thanks:
Is the swing arm moving at the frame? If so you need to replace your swing arm bearings. I just did the same job 2 weeks ago.
Edited by fracas
Time to buy a rebuild kit. All-balls and pivot works make kits. They'll come with new bearnings, seals, dust caps, washers, and a sleeve.
ok thanks that is what i taught i had to do :thumbsup:
all balls or pivot works is the way to go...
