just got my swing arm bearings in and put evrything back together and for a a couple hours and when i get off the quad it squeaks really loud and bad also i can just push the back end down and it does it like that too i have greased everything and sprayed oil on everything and still does it any suggestions
when you replaced the swing arm bearings did you also replace the tube in the middle if not that tube could have mars in it from before and burning up your new set of bearings. or be too tight in some places causing it to squeek because it is rubbing the bearings wrong.
