vitovito240 Posted May 30, 2007 Report Posted May 30, 2007 whats up everyone? i have the Trinity 2 into 1 carb set up that i bought a while ago. the thing is my carb is shot and needs to be replaced for many differnet reasons. with that being said can i still use all the other parts in the kit like the stage 1v alloy manifold, carb manifold as well as air box adapter plate on any other aftermarket carb for the banshee? or do i need to stick w the same one it came with? thanks Quote
dajogejr Posted May 30, 2007 Report Posted May 30, 2007 You can use any two stroke carb (single) that will fit in the intake boot and seal properly....there's nothing special. I'd recommend at least at 35PWK for a single setup, though... Quote
