I have a graydon 2 into 1 intake that I want to run. I had it on the bike,but the throttle cable is too short. Is there a longer cable out there that I can use? I have a twist throttle on it now,but I can also run the thumb throttle setup. I was told that a blaster cable would work with the thumb throttle setup,but the carb end fitting is way different. I am currently running my trinity 2 into 1 intake until I can figure this problem out. If it helps I am running a keihin 35mm PWK. Any help would be great. Thanks.
Garry
