I am getting ready to install the following:
Pro Design Billet Impellar
Pro Design Billet EZ Drain Water Pump Cover(w/ new bolts & gasket)
Total: $111.90
Will I need the gasket for the Crankcase/Clutch cover? Also will I need the water pump bearing and seal? My bike is only a year old from brand new. I don't want to spend the money if I don't need to, because it is $40 for these extra parts. If I need these to be on the safe side let me know.
your gonna need the gasket for the drain plate,i would replace the seal and the bearing since your gonna be there the bearing and seal cost next to nothing.oh and the clutch cover gasket also if you's is torn up.
Spend the money and just get a full gasket kit, its a nice thing to have lying around just in case. If the gaskets are still good when you come apart, reuse them. If they start leaking, you have extras lying around and you can just replace them and not have any down time but the time to change them.
