OnlyA2Stroke Posted May 27, 2007 Report Posted May 27, 2007 I just tried installing a new G-force axle from RM-ATV. I followed the shee instructions/picture and it still doesn't measure the same length on each side of the axle from the middle of the swingarm carrier. They are almost 3/8" off from the center. What pieces did you guys use out of the kit? I received axle, (3) c-clips, (2) spacers: 1 small(diameter), 1 large(diameter), 3 piece axle nut (allen bolt, outer axle nut, inner axle nut), 4 hub/wheel spacers, 2 thick ones and 2 thin ones. Now which of these pieces do I use and when I followed another link in here it was short on the right side(from the rear of the atv). Do I put a spacer on the right side to make the tire/wheel stick out futher? Thanks Quote
jlsparky7 Posted May 27, 2007 Report Posted May 27, 2007 You dont need the smaller spacer. Ill take some pics and put them up tomorrow. I had a PITA time putting my axle on too. P.S. Make sure you install new bearings when you do the new axle, just to save you time and headache later on. Quote
Hollister_Hitman Posted May 28, 2007 Report Posted May 28, 2007 here you go: http://www.bansheehq.com/forums/index.php?...347&hl=axle Quote
jlsparky7 Posted May 29, 2007 Report Posted May 29, 2007 here you go:http://www.bansheehq.com/forums/index.php?...347&hl=axle Beat me to it. Quote
