downNdirty Posted May 23, 2007 Report Posted May 23, 2007 Ok so I just bought a used FMF fatty exhaust. My bike has no work done to the motor at all. Stock motor stock carbs and even stock air filter and box. What I need to know is what jet kit I need? And do I need to replace the filter and air box? Actually I think I did order a k@n fliter with a outwear. Damn I dont remember. I just dropped over a grand this weekend on parts and I cant remember everything I ordered. anyway. Another question. Does filter and box make a difference when it comes to the jet kit? Any info would be greatly apprecated. AND thank you for your time. Quote
Handyman Posted May 23, 2007 Report Posted May 23, 2007 You should have gone with the K&N filter pods...would wake your shee up unless you ride a lot in water... Anyways....before you buy the jet kit see where your jetting is after you install the new filter. More than likely you'll have to rejet to a bigger main jet since you'll be pulling more air with the K&N filter..More air means more fule needed. Quote
bansheeyfz Posted May 23, 2007 Report Posted May 23, 2007 just buy individual jets. its cheaper. Quote
downNdirty Posted May 23, 2007 Author Report Posted May 23, 2007 Thanks for the info guys. I will be riding through puddles and streams from time to time. So I should go with a regular filter and not the pods right? Quote
fastrthnu Posted May 23, 2007 Report Posted May 23, 2007 Thanks for the info guys. I will be riding through puddles and streams from time to time. So I should go with a regular filter and not the pods right? yes^. if your bike hasnt had any mods done to it yet, and you put fmf fatties on there and filter and try to run it to see what it runs like,. Ill tell you,..... very very lean. If you going to leave the stock airbox on which Id recommend for in water and mud, you can still flow it alot better with a pro flow adapter leaving the lid off. A starting point for your jetting would be more helpfull to give with an altitude and temp range. Quote
KaosBanshee44 Posted May 23, 2007 Report Posted May 23, 2007 Yeah if your gonna be going through water i would just get a regular K&N for the stock air box. That's what i have on mine but i don't want it i want the double k&n filters on mine so i'll sell you my air filter if you want it so i can get the double filters. Quote
downNdirty Posted May 24, 2007 Author Report Posted May 24, 2007 yes^. if your bike hasnt had any mods done to it yet, and you put fmf fatties on there and filter and try to run it to see what it runs like,. Ill tell you,..... very very lean. If you going to leave the stock airbox on which Id recommend for in water and mud, you can still flow it alot better with a pro flow adapter leaving the lid off. A starting point for your jetting would be more helpfull to give with an altitude and temp range. ok altitude is pretty much sea level, and about the temp range well i live in New Jersey so its friggin hot an humid all summer. Quote
