Right now Im running mikuni VM30 carbs with an aggressive port job,needle on first clip,27.5pilot,330 main.Off idle responce is at its best when air/fuel screw is all the way in at its leanest point.Does this mean I need a smaller pilot.
Second question I went up in carb size from my stockers to 30mm I should have to run a smaller main than the stockers and Idont. I dont know if its because the jets are universal from stock to 30mm
I think I might need a different needle also?
PLEASE HELP!!!
