XxMeltIcexX Posted May 13, 2007 Report Posted May 13, 2007 I have Vforce 3 reeds, stock reeds come with the round reed stuffer - i have trinity intake with square bore. Will this affect enough to make a change of 20 psi of compression? The reeds stuffers on cascade will fit and make them square, but is that why i'm down 20 psi of compression? (I put in stock reeds i'm getting 20 psi more, reeds all intact - both vforce3 and stock - not too much tension and no cracks..etc.) Thanks, Eric Quote
dajogejr Posted May 14, 2007 Report Posted May 14, 2007 No...a lot people are using the square stuffers...myself included. YOu mentioned in the other post, you were using a cheapy 35 dollar tester...have you tried another tester yet?? Quote
