Whats the must have's for a good 4mill Drag Cub
Guest WICKED ATV
I am in the process of building a 4mill drag cub. I using cylinders from RDZ. What are some other things i need like type of crank, size carbs ect.... Im wanting to run straight race fuel and its gonna be on asphalt most of the time.
You're gonna need a lot of $$$$ :yelrotflmao:
Are you getting the cylinders from Rob @ RDZ...or where they just done up by RDZ??
Wiseco hot rod crank rewelded will work just fine. Factory welds are crap.
A lockup and Override are an absolute must for a cub and for drag racing.
The rest is gonna be saving weight via chromoly parts (suspension components, etc.), drag axle...etc.
Also, gearing and tuning to no end.
Since you're gonna be on pavement....race gas might be the best ticket. For long runs, longer than 1/8 mile...it's hard to feed enough alky to these motors....even with pumps, larger bowls, removing a float...etc.
Guest WICKED ATV
THANKS FOR THE INFO. AND FOR THE CYLINDERS, I GUESS IM JUST BUYING DRAG PORTED CYLINDERS THAT ARE ADVERTISED ON THEIR WEBSITE. OHH AND THEIR NEW BILLET HEAD.
You'll have PM in just a few....
