danysbanshee Posted May 7, 2007 Report Posted May 7, 2007 (edited) Hey guys. I've been searching tryin to estimate how much power my 02 is gonna push. I was wondering if one of you guys might have a better idea. Plus this weekend I just sent my jugs out for a flow tested trail port. Befor that my mods were as follows. fmf gold series pipes, 35mil shaved head, bored 20 over, adjustable timing plate @ 5 degrees along with the lid removed on the air box. Iam now going to add the port with 19cc domes on a new head and 104 octane with clamp ons. Any estimates on b4 and after? How much am i gonna benefit 3 from a set of v force 3 reeds and the aluminum head vs. the stocker? On a side note iam only a couple hundred feet above sea level. Edited May 7, 2007 by danysbanshee Quote
sldbanshee Posted May 7, 2007 Report Posted May 7, 2007 Hey guys. I've been searching tryin to estimate how much power my 02 is gonna push. I was wondering if one of you guys might have a better idea. Plus this weekend I just sent my jugs out for a flow tested trail port. Befor that my mods were as follows. fmf gold series pipes, 35mil shaved head, bored 20 over, adjustable timing plate @ 5 degrees along with the lid removed on the air box. Iam now going to add the port with 19cc domes on a new head and 104 octane with clamp ons. Any estimates on b4 and after? How much am i gonna benefit 3 from a set of v force 3 reeds and the aluminum head vs. the stocker? On a side note iam only a couple hundred feet above sea level. well im not sure the power but with the 19cc domes the compression is going to be alot higher and the reeds will just greatly improve the gas and air flow creating a accelaration boost also making it have more power so going weith the domes and reeds your looking at alot more power torqe speed its all to benefit from...but with the 19cc domes ive heard they dont idle well at all...but im getting them too so good luck Quote
danysbanshee Posted May 7, 2007 Author Report Posted May 7, 2007 well im not sure the power but with the 19cc domes the compression is going to be alot higher and the reeds will just greatly improve the gas and air flow creating a accelaration boost also making it have more power so going weith the domes and reeds your looking at alot more power torqe speed its all to benefit from...but with the 19cc domes ive heard they dont idle well at all...but im getting them too so good luck 19cc's is what ive been recommend to run by my local shop. He didnt mention anything about idle. i'll have to hit him up with that? Quote
