RagunCajun Posted May 6, 2007 Report Posted May 6, 2007 (edited) I'm sending my jugs off to be ported and my flywheel off to be lightened monday. As i started to take the juggs etc out, i noticed i will need a few things: *new top end *oring gasket kit for my top end *oring kit for my NOSS head *ADJUSTABLE STATOR /TIMING PLATE *toomey t5's(im selling my t6's) *20cc domes for my NOSS head *"allen headed" screws for my clutch cover and flywheel cover or whatever it's called I'm look on the F.A.S.T.'s webside right now. I see the oring kit that will work with my head and other designs. Here's a few questions. I see the ACORN NUTS FOR COOL HEAD. Does that come with the little brass washers? Also, what kind of K&N pod filters will fit my stock carbs. There's different sizes for those filters and the outwares that go over them. I need to know where i can find some screws for my clutch cover and stator/flywheel cover that has an head that an allen wrench can fit. The phillips head screws strip too easy. BTW, if you think i am missing anything, please let me know. I took out my cylinders and my flywheel. the only other things that were taken off where what i needed to get to those things. thanx -Cody Edited May 6, 2007 by RagunCajun Quote
Hilarious Posted May 6, 2007 Report Posted May 6, 2007 I'm sending my jugs off to be ported and my flywheel off to be lightened monday. As i started to take the juggs etc out, i noticed i will need a few things:*new top end *oring gasket kit for my top end *oring kit for my NOSS head *ADJUSTABLE STATOR /TIMING PLATE *toomey t5's(im selling my t6's) *20cc domes for my NOSS head *"allen headed" screws for my clutch cover and flywheel cover or whatever it's called I'm look on the F.A.S.T.'s webside right now. I see the oring kit that will work with my head and other designs. Here's a few questions. I see the ACORN NUTS FOR COOL HEAD. Does that come with the little brass washers? Also, what kind of K&N pod filters will fit my stock carbs. There's different sizes for those filters and the outwares that go over them. I need to know where i can find some screws for my clutch cover and stator/flywheel cover that has an head that an allen wrench can fit. The phillips head screws strip too easy. BTW, if you think i am missing anything, please let me know. I took out my cylinders and my flywheel. the only other things that were taken off where what i needed to get to those things. thanx -Cody What kind of port are you getting? And who is doing it for you? RockymountainATV should have most of what you are looking for. They have the clutch cover and stator cover bolts in stainless, allen head by Tusk. They also have the k&N pod filters with outwears in a kit, for stock carbs. As for the acorn nuts, you may pm dlnoss and ask him directly. I know when I got my noss head, that it came with the acorn nuts and little copper washers. Good luck with your build. :thumbsup: Quote
RagunCajun Posted May 6, 2007 Author Report Posted May 6, 2007 http://flotek.everything2stroke.com/ is doing it. Im getting an aggressive trail port and im gonna be using 93 pump gas. We talked about it so i know what i want and need to make the port job, pipes etc work in sync. And thanx, i will visit rockymountain's site tomarrow and take a look around. I hear they are cheap and that is where i planned to order my t5's from. Quote
Snopczynski Posted May 6, 2007 Report Posted May 6, 2007 dont forget to get wrist pin bearings also. Quote
FASTOYS Posted May 6, 2007 Report Posted May 6, 2007 We have all of what your looking for and you can save a ton on shipping from here and there and get it all at one stop. Quote
RagunCajun Posted May 6, 2007 Author Report Posted May 6, 2007 (edited) dont forget to get wrist pin bearings also. what's that? and FASTTOYs, can i order it online or do i have to call the order in over the phone? Edited May 6, 2007 by RagunCajun Quote
bentvalve Posted May 6, 2007 Report Posted May 6, 2007 yeah he is a great guy to deal with(jeff at fast) i just got my cpi's,clutch,and a bunch of little stuff for the carbs,modded shift star. this is my second large order with him. call him on the phone talk to him about what you need or want he has it in stock. check his web site for all of his stuff. don russell Quote
FASTOYS Posted May 6, 2007 Report Posted May 6, 2007 Give us a call . That way you and i both know that its in my hand and not a empty bin in some warehouse but the computer says its in stock like some places.. lol Quote
RagunCajun Posted May 6, 2007 Author Report Posted May 6, 2007 That sounds good man, ill ask to speak to you jeff when i make the order soon. Thanx. Quote
