hey .. im a total newbe with my banshee. What exactly are metal things on top of the carbs ... and how do i adjust them .. also if u swap them , would it cause problems ?? also does it tell yuo wut side thay are each sopoosed to go on. please explain .. thank you
i belive your talkin bout the stupid tors ./ idle screw things... if you have them off already you can buy a tors overide kit thing and it gives you new tops and really helps on jetting later down the road. 50 dollar investment WORTH IT ! , also click the link in my signature it will tell you about the tors somewhat. I have removed the tors feature on all my bikes and know several other people who do the same , best advice i can give you is, read up on here man , the questions been answerd probly 50 times over.
just my .02
okay i was reading the thread... by cuttin those wires it makes it totally useless ... even the idle screws? ause right now mines fucked up and jus revs out on its own like sum1 is giving it gas then not and giving it gas and then not .. over and over
