josh0440 Posted May 1, 2007 Report Posted May 1, 2007 Hey everyone, I just have recently purchased a 97 banshee that was not running. I cleaned both carbs and got it running, but only on one cylinder. I took the carbs back off and cleaned them again, with still the same result. I changed the plugs and still the same thing. The right side runs great, but the left side doesn't. From an idle I could hear the left side start to kick in a little, but with the throttle it would die back off. I got a clymer manual on it and from what the book seems to tell it is maybe an electrical problem such as the coil. Just wanted to see if anyone has had a similar problem, or if anyone could give me a little help with it. I've been in the 2-strokes awhile now, but this is my first banshee, and any help would be appreciated. Quote
RIPRuck Posted May 1, 2007 Report Posted May 1, 2007 Switch the plug wires and see if that side runs. Quote
