will the pistons travel past 0 deck height even with 795 series pistons ? will i have to have my domes cut ?
If you are running a stroker crank and OEM pistons without a spacer plate, yes...they will travel past 0 deck.
That's why you get the head/domes cut, the piston will slightly run up into it.
795 series are used because of a longer rod, NOT the stroker crank (110mm is stock rod length, 115 is long rod)
Good point, Jeff.... I need to start thinking in terms of "not" drag racing...my bad.
