felcon edition banshee Posted April 14, 2007 Report Share Posted April 14, 2007 1: how does a cooling head actually cool down the engine 2: it is said to improving preformance 2.1: does it? 2.2: if it does by how much 2.3: if it does why/how does it do it? 3: is a cooling head worth it for a hugely small budget (i got $500 to spend) any help would be worth it Quote Link to comment Share on other sites More sharing options...
BansheeKid15 Posted April 14, 2007 Report Share Posted April 14, 2007 1: how does a cooling head actually cool down the engine 2: it is said to improving preformance 2.1: does it? 2.2: if it does by how much 2.3: if it does why/how does it do it? 3: is a cooling head worth it for a hugely small budget (i got $500 to spend) any help would be worth it 1. it allows more coolant to enter into the head, cooling it off better 2. yes, depends on what domes/altitude/octane 3. depends 4. by enterchanging the domes for higher/lower compression 5. yes... i would buy a coolhead. I dont know what you have on your bike or dont have, so post your mods and people will help you out. Quote Link to comment Share on other sites More sharing options...
felcon edition banshee Posted April 14, 2007 Author Report Share Posted April 14, 2007 1. it allows more coolant to enter into the head, cooling it off better2. yes, depends on what domes/altitude/octane 3. depends 4. by enterchanging the domes for higher/lower compression 5. yes... i would buy a coolhead. I dont know what you have on your bike or dont have, so post your mods and people will help you out. try looking at my sig (i only got tires and spacers lol) Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted April 14, 2007 Report Share Posted April 14, 2007 aluminum conducts heat very well,. and when you can get more fluid through it it takes more heat away. Because of this you can run a slightly higher compression with advanced timing on pump gas.The combo of this and a timing plate will be nice. They look much better than stock. And if you have the choice to look looker..... Get a noss head instead of a cool head. dont have to change studs and they look better. Quote Link to comment Share on other sites More sharing options...
felcon edition banshee Posted April 14, 2007 Author Report Share Posted April 14, 2007 aluminum conducts heat very well,. and when you can get more fluid through it it takes more heat away. Because of this you can run a slightly higher compression with advanced timing on pump gas.The combo of this and a timing plate will be nice. They look much better than stock. And if you have the choice to look looker..... Get a noss head instead of a cool head. dont have to change studs and they look better. will they cool as well coz problem is i drive in deserts upto 30-37 celcius. also will they cost as cheap (as mensiond on budget) Quote Link to comment Share on other sites More sharing options...
BansheeKid15 Posted April 14, 2007 Report Share Posted April 14, 2007 they are about the same price... i didnt see your sig when i posted, lol, my bad. But cool head and timing advance. btw, do you have the stock pipes on the bike or aftermarket? Quote Link to comment Share on other sites More sharing options...
JET 99 Posted April 14, 2007 Report Share Posted April 14, 2007 noss head is about $240.00 US i think $235.00 actually from a builder whos banner is on top of some of the forum pages.(i dont want to start a builder pissin match on your thread) :beer: . its a good head... has interchangable domes.. dont go wild on compression yet. you still have a stock crankshaft. needs to be trued and welded if you start running hi compression.. but with the interchangable domes later if you go further with your mods. you can change domes and not get a whole new head... Quote Link to comment Share on other sites More sharing options...
bansheeyfz Posted April 15, 2007 Report Share Posted April 15, 2007 im still trying to find out what in the hell is a felcon edition? Quote Link to comment Share on other sites More sharing options...
