woodwardspecialties Posted April 13, 2007 Report Posted April 13, 2007 This is a USED ACE Fabrication Swing arm for a Yamaha Banshee. It comes with the bearings installed as well as the bushings and OEM pivot bolt. It also has the Rad Manufacturing twinrow bearing carrier with 250r style chain adjustment, as well as the brake caliper bracket that allows the use of your stock Yamaha banshee rear brake system. This is setup to use the OEM or equivalent YAMAHA BANSHEE axle. i don't the if it is extended or not, but measuring from end to end, i get 22 1/2 inches This item was removed from a USED 2001 Yamaha Banshee. Most parts are interchangeable between all of the Yamaha banshees however, you should check on the fitments of the item with your dealer before purchasing. I can gaurantee this item was from a 2001 Yamaha Banshee 350. $400 shipped UPS ground in the 48 states Quote
dwrracing Posted April 16, 2007 Report Posted April 16, 2007 damn is there anyway u can find out if it is exstended or not? Quote
woodwardspecialties Posted April 17, 2007 Author Report Posted April 17, 2007 damn is there anyway u can find out if it is exstended or not? i posted the measurment... you can measure your stock one... Quote
bada450r Posted April 17, 2007 Report Posted April 17, 2007 +21/2,if theres such a thing. :cool: Quote
dajogejr Posted April 17, 2007 Report Posted April 17, 2007 Just measure the middle of the axle to the middle of the swingarm bolt on a stocker... It looks stock length to me, very nice lookin arm Good luck! Quote
woodwardspecialties Posted April 18, 2007 Author Report Posted April 18, 2007 still available... make offers... must go! Quote
