LtDan Posted April 6, 2007 Report Posted April 6, 2007 Last week I installed some oversized tires, now the gear ratio needs to be corrected. If I toss a new rear sprocket on a fairly used chain (and front sproket) to get though the weekend, will I run into any problems. Has anyone replaced the rear sprocket until you had time to get a new chain/ front sproket set installed? I dont want to get trap myself this weekend -thanks- Quote
KHall Posted April 6, 2007 Report Posted April 6, 2007 Last week I installed some oversized tires, now the gear ratio needs to be corrected. If I toss a new rear sprocket on a fairly used chain (and front sproket) to get though the weekend, will I run into any problems. Has anyone replaced the rear sprocket until you had time to get a new chain/ front sproket set installed? I dont want to get trap myself this weekend -thanks- I put a 12 tooth sprocket on the front and left the old chain and rear sprocket on and I havent had a prob If it is a O-ring chane u should B fine Quote
fastrthnu Posted April 6, 2007 Report Posted April 6, 2007 Last week I installed some oversized tires, now the gear ratio needs to be corrected. If I toss a new rear sprocket on a fairly used chain (and front sproket) to get though the weekend, will I run into any problems. Has anyone replaced the rear sprocket until you had time to get a new chain/ front sproket set installed? I dont want to get trap myself this weekend -thanks- I think you should be alright for the weekend. Its usually the sprockets that have to be changed when changing the chain. Quote
LtDan Posted April 6, 2007 Author Report Posted April 6, 2007 (edited) sounds like a winner- the more i read about gearing, im thinking about changing the front sprocket. i put the 22inch razor2's on the rear- they look like balloons! but they climb a hill like a champ- thanks Edited April 6, 2007 by LtDan Quote
MILO Posted April 6, 2007 Report Posted April 6, 2007 you should be fine. it's just a matter of it being best to change everything together if one or the other is worn significantly cuz it will cause premature wear on the new parts. Quote
