banshee43 Posted April 2, 2007 Report Posted April 2, 2007 when im messing around at home its fine but then i go to silver lake dunes and the throttle sticks and gets sensitive im thinking of getting new slides and new thumb throttle and cables my tors are removed eny advice please tell thanks Quote
MILO Posted April 2, 2007 Report Posted April 2, 2007 maybe your just getting sand in places that it doesn't belong seriously bud, what kind of air filter are you running? it may be letting sand particles through and into your carb and jamming up the slides. that can be hell on your cylinders also. K & N filters are usually better for sand environments than foam filters are. if your still running the stocker, get rid of that pos, anything is an improvement from that set up. a pro design adaptor plate with a good filter may be what you need. :cool: pro design adaptor / filter Quote
banshee43 Posted April 2, 2007 Author Report Posted April 2, 2007 maybe your just getting sand in places that it doesn't belong seriously bud, what kind of air filter are you running? it may be letting sand particles through and into your carb and jamming up the slides. that can be hell on your cylinders also. K & N filters are usually better for sand environments than foam filters are. if your still running the stocker, get rid of that pos, anything is an improvement from that set up. a pro design adaptor plate with a good filter may be what you need. :cool: pro design adaptor / filter nah dude i no how that air filter stuff works i use knn with that nasty spray and then outerwear Quote
MILO Posted April 2, 2007 Report Posted April 2, 2007 nah dude i no how that air filter stuff works i use knn with that nasty spray and then outerwear sorry bud, i don't know what else to tell you then. did you try just lubing the cable? you may be up for some new cables and so on after all. good luck. Quote
banshee43 Posted April 2, 2007 Author Report Posted April 2, 2007 sorry bud, i don't know what else to tell you then. did you try just lubing the cable? you may be up for some new cables and so on after all. good luck. ya thanks for the help u no what all that crap goes for and a place to get it?? Quote
Screaming Yellow Zonker Posted April 2, 2007 Report Posted April 2, 2007 just a thought have you checked your needles to make sure they are straight? Quote
MILO Posted April 2, 2007 Report Posted April 2, 2007 not sure about the slides, but rocky mountain has decent prices on cables and levers. rocky mountain atv.com Quote
banshee43 Posted April 3, 2007 Author Report Posted April 3, 2007 well i think i found the proplem when i removed tors theres a hole on the side of the throttle and i forgot to plug it but there was a little sand in carbs Quote
