I was riding the shee last night and it was running good. It is on the rich side because my new filter kit hasn't come in yet but it was still running good. I pulled it off the truck today and started it to ride around the house to the water hose so that i could wash it off and when i tried to give it throttle it bogged downed real bad. It would not pick up rpms worth a damn. I pulled the plugs and they looked like they were fouled so I replaced them and that didn't help at all. The mods to my she are as follows: DG pipes, and uni filter in stock box, 280 mains needle in stock position, and air screw turned 1 turn out.
Any help would be appreciated.
Have you unhooked the TORS assembly and the parking brake switch?
forgot to put that in the list of mods. It does have the tors elim kit.
This just made me think that I did just remove the parking brake assembly and I just went outside and removed the parking brake switch and mashed the button and now shee revs like shee is supposed too. Thanks for the help, but now how do you go about disabling that switch?
try using the search function bud. odds are that almost any problem you have has been addressed before. chech out this link.
clicky
