rjbestracing Posted March 27, 2007 Report Posted March 27, 2007 BOUGHT 2002 BANSHEE, PREVIOUS OWNER SAID HE HAD GOTTEN WORK DONE AS FOLLOWS. .30 OVER WIESICO PISTONS, HE ALSO TOLD ME HE MILLED THE STOCK HEAD 20 -25 THOUSANDS, BIKE ALSO HAS CPI INFRAME PIPES WITH STOCK CARBS, BIKE ORIGINALLY CAME TO ME WITH FMF SST PIPES AND THE CARBS CAME JETTED FOR THOSE PIPES, I THEN PURCHASED THE CPIS AND THROUGH THEM ON (LEFT JETTING THE WAY IT WAS) BIKE RAN GREAT WITH CPIS BUT IS NOT DOING GOOD ON TOP END NEED SOMEONE TO HELP ME OUT WITH JETTING? I ALSO JUST ORDERED V-FORCE REEDS AND IAM THINKING ABOUT ADVANCING THE TIMMING ON THE MOTOR, CAN SOMEONE PLEASE GUIDE ME ON HOW TO JET THE BIKE IF IAM PUTTING V FORCE REEDS AND ADVANCING THE TIMING, DONT KNO WAT SIZE JUST TO BUYS THX YOU ALL FOR YOUR TIME, PLEASE LET ME KNO OF ANYTHING THAT CAN HELP ME Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 BOUGHT 2002 BANSHEE, PREVIOUS OWNER SAID HE HAD GOTTEN WORK DONE AS FOLLOWS. .30 OVER WIESICO PISTONS, HE ALSO TOLD ME HE MILLED THE STOCK HEAD 20 -25 THOUSANDS, BIKE ALSO HAS CPI INFRAME PIPES WITH STOCK CARBS, BIKE ORIGINALLY CAME TO ME WITH FMF SST PIPES AND THE CARBS CAME JETTED FOR THOSE PIPES, I THEN PURCHASED THE CPIS AND THROUGH THEM ON (LEFT JETTING THE WAY IT WAS) BIKE RAN GREAT WITH CPIS BUT IS NOT DOING GOOD ON TOP END NEED SOMEONE TO HELP ME OUT WITH JETTING? I ALSO JUST ORDERED V-FORCE REEDS AND IAM THINKING ABOUT ADVANCING THE TIMMING ON THE MOTOR, CAN SOMEONE PLEASE GUIDE ME ON HOW TO JET THE BIKE IF IAM PUTTING V FORCE REEDS AND ADVANCING THE TIMING, DONT KNO WAT SIZE JUST TO BUYS THX YOU ALL FOR YOUR TIME, PLEASE LET ME KNO OF ANYTHING THAT CAN HELP ME Three things: 1.)Don't type in all capitol letters because no one will read your post and reply to it. 2.)Not rejetting the carbs after installing the CPI pipes more than likely has made your engine run extremely lean. If you have been riding the bike around like that for any period of time you can pretty much count on the top end of the motor being ruined. 3.)What are you running for an air filter and porting? Quote
rjbestracing Posted March 27, 2007 Author Report Posted March 27, 2007 (edited) Three things: 1.)Don't type in all capitol letters because no one will read your post and reply to it. 2.)Not rejetting the carbs after installing the CPI pipes more than likely has made your engine run extremely lean. If you have been riding the bike around like that for any period of time you can pretty much count on the top end of the motor being ruined. 3.)What are you running for an air filter and porting? just a stock air box with uni air filter and stock lid the only thing i did was remove snorkal, as faar as porting when i bought the bike the man just told me he milled the head 25 thousands for more compression is that alot Edited March 27, 2007 by rjbestracing Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 just a stock air box with uni air filter and stock lid the only thing i did was remove snorkal I really don't know what to reccomend. I have never run a setup like you have with a stock air box. Quote
dajogejr Posted March 27, 2007 Report Posted March 27, 2007 You should probably keep this all in the same thread. Mark...in his other post (as you're probably readin now) he has a 16 TOOTH front sprocket. I think we've found the problem. Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 You should probably keep this all in the same thread.Mark...in his other post (as you're probably readin now) he has a 16 TOOTH front sprocket. I think we've found the problem. I didn't realize it was the same guy. I was just responding in the other thread to your post...............and I had to flip back and forth between the threads as I thought I had double posted, entered a parallel dimension, or something equally strange. Quote
rjbestracing Posted March 27, 2007 Author Report Posted March 27, 2007 (edited) You should probably keep this all in the same thread.Mark...in his other post (as you're probably readin now) he has a 16 TOOTH front sprocket. I think we've found the problem. why is a 16t sprocket a problem, i ran the bike last weekend in an 1/8 mile track and i beet most of the quads there, but the bike was not running to its potential it couldint launch because it would pop up and if i would get a good launch it would spin all 1 and 2 gear, bike ran a 8.7 at 78 mph best time of the night Edited March 27, 2007 by rjbestracing Quote
dajogejr Posted March 27, 2007 Report Posted March 27, 2007 1/8 mile pavement or dirt? Pavement I'd bet...and there isn't much resistance, rubber to road...so, you can get away with that kind of gearing. You specifically said it's running great up until the top of 6th gear. It's one of two things. The jetting is lean on the top end...or you're geared too high with not enough motor to pull it. Being it's a stock motor...I think it's geared to high. But, a plug chop done properly will tell. If the plug is white after a proper chop, increase the main 2 sizes, then do it all over again. Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 1/8 mile pavement or dirt?Pavement I'd bet...and there isn't much resistance, rubber to road...so, you can get away with that kind of gearing. You specifically said it's running great up until the top of 6th gear. It's one of two things. The jetting is lean on the top end...or you're geared too high with not enough motor to pull it. Being it's a stock motor...I think it's geared to high. But, a plug chop done properly will tell. If the plug is white after a proper chop, increase the main 2 sizes, then do it all over again. He is obviously way lean if he didn't refet between the FMF and CPI pipes. :thumbsup: Quote
