Hey guys you probably read my post about no spark on my shee. I was wondering if any one out there had a stock CDi unit that would fit my 1996 Banshee. I know many of you have one lying around in a box. Looking to borrow or get one cheap to figure out if mine is bad. thanks, Derek
Actually....95-96 are the most rare ( I know...cause I have one)... 87 to 94 was the same and 97 to current are the same.
I don't know you and you're a newer member here ....so...here's what I'm willing to do for you.
Part honesty/trust, part money up front.
I have a used 96 stock CDI I keep as a spare ( I run an aftermarket Dyna Ignition)
If you want to paypal me 50 dollars, I will send it to you via Fed Ex...to use as a test to see if it's the problem.
When you're done...simply send it back...and I will credit you the money back (minus my cost to ship to you, probably 7 to 10 bucks)...
If that sounds fair to you, let me know. I'm sorry to ask for a deposit, but as said...you're new here. If you'd like, have a senior member here vouch for you, and I'll send it to you for the cost of shipping only...on the preface that it will be sent back within a reasonable time frame (week or two) once you test it and see if that's the culprit.
You can ask around here, I'm not a BSer and I don't pull any punches....
Just let me know...it's sitting in the bottom of my tool box at home. If you can...please post a pic of the wire ends to make sure you'd be getting the correct one to test....
Dave
