what i have is a 93 bored 50 over with a cool head (18cc), VForce 2 cage/reeds, twin k&n filters with outerwears, Toomey T-5's, RickyStator set +4 adv, needles are on the middle clip with stock needles, Elevation 4953 ft, Eng Compression 153 on the left 151ish on the right as of now its got 270 mains and 30 pilots and this thing is a pain in the ass to start if it ever does but when its started seems to run great is there anyone out there running about the same setup around my elevation that can give me some idea's on if the jetting is right or just anyone's options on what its set at now
Thanks for any help...
Put stock pilots back in (25) You're way too fat on the pilots, period. The rest sounds close...but do a plug chop to check your main, I think you're a little lean there...might need 280 or 290 IMO.
Thanks for the reply im going to get some jets tomorrow i will try the mains you suggested also dont you need a larger pilot with the use of pipes?
