too_fazt Posted March 12, 2007 Report Posted March 12, 2007 alright here it is, bike is a pain in the asss to start, (starter fluid helps it right away, and it idles pretty well. but.......after about an hour of driving my left side started to sputter every now and then, i then noticed my right side was blowing smoke and left nadaaa......idle wot left side isnt running right.....i checked the plugs, there ok....i swaped the plug caps and then the plugs themselves....but....same problem....after that im pretty much in the dark....let me know what you guys think.... Quote
yamaha04 Posted March 12, 2007 Report Posted March 12, 2007 check your reeds for cracks ,chips. cheack carbs, clean carbs, check compresstion then get back to use Quote
dajogejr Posted March 12, 2007 Report Posted March 12, 2007 Compression then leak down test to check for air leaks. Quote
