bansheeyfz Posted March 8, 2007 Report Posted March 8, 2007 i just bought these cheap lights . they didnt come with instructions. so what wire do i cut then connect? could someone give me A step by step instruction on these? Quote
bansheeyfz Posted March 8, 2007 Author Report Posted March 8, 2007 my bad i forgot the link here you go Quote
differentstrokes Posted March 8, 2007 Report Posted March 8, 2007 (edited) You can cut the stock light plugs off your wiring harness and wire the high and low beam wires together(green and yellow) then wire them to the single bulb wire. There should also be a ground wire from the lights that wires to the ground from the harness(black). I'm assuming these are single beam lights is why you wire the yellow and green hi/low together. I'd change the bulbs to 35w unless you have an aftermarket stator too. Edited March 8, 2007 by differentstrokes Quote
grpark20 Posted March 8, 2007 Report Posted March 8, 2007 Post some pics once you get those installed. Let us know how bright they are too. Been debating on buying those for a while. Thanks Quote
bansheeyfz Posted March 8, 2007 Author Report Posted March 8, 2007 i will post some pics! Does anyone else think i need to upgrade my stator. if i run them what would happen? Quote
